Mounting Rad/T-Line/Pump below PC
Justshoe
Im planning on making a box that will be mounted underneth my pc to house my rad/pump/psu for pump and fans. Is it ok to do this without fear of never getting air out? I figured for bleeding i could make a 3ft or so long t-line maybe that would stretch to above the pc to allow air out. is anyone else doing this does it cause any issues? Also whats the verdict on fan shrouds? Im goin to be using a dodge intrepid heatcore, beasty lil thing btw, and im debating on designing fan shrouds for it or would i be ok with 4x120mm fans on the front and back.
1) Shrouds do give slightly better performance, but if you're going to cover that beastly core with all those fans it might not make a difference. Still I prefer shrouds.
2) T-line does not have to be at top of pc, nor does the tubing need to be long.
Cool so you'll think i can get away with standard fill procedures and such with everything mounted below pc.
btw heres the core:
