Mounting Black Ice Xtreme
I am installing a water cooling setup for the first time and I am having trouble figureing out where I should mount the Rad. I have a Cooler Master ATCS case. The total specs on the watercooling setup are... a danger den maze 4 cpu block, danger den maze 4 gpu block for ati radeon, L30 pump, round res, black ice xtreme obviously. The rad doesn't have screw holes all the way though, instead it has screw holes on each side so I cant really mount it with long threaded bolts. I am thinking about mounting it on top of the case. Any pics would be helpful thanks. (btw I have looked through the wc pic thread pinned.)
I need to get my older pics out but I used a 2in 440 thread bolt (i think it was a 440) but that passed thru the grill,case grommet,fan and into the rad just perfectly :)
Originally posted by dead2self03
It does go through the black ice xtreme?
the shroud has those mounting holes in the corners...the 2in bolts actually secure into those...no need to go all the way thru the rad
I really can't fit the rad at the bottom front of the case, what is the best way to mount it to the top or another place to mount it? Thanks.
