Hi.
I have cylindrical (word?) pump thats about 4" tall and a 5" diameter. Its has dual internal pumps and a reservoir in the unit. My problem is I cant figure out how i should mount a pump of its form to my case (im planning on permantly mounting it somewhere below the AGP and around the bottom PCI slots), but i was thinking about using some kind of tension clip like you might find on a traditional hs/f to hold on the heatsink. problem is i have no idea how i would fabricate a clip like that to hold it on. one problem is theres no real tabs or wings on it that i could possibly screw through for attaching supports.
any help or good idea's that i could actually perform would be really appreciated.
thanks.
** I'll try to get a picture of my pump (and case?) **
thanks.
