I have the Black Ice 480, which is a huge rad. I'm trying to figure out how to effectively mount it on a CMS stacker 830 (inside is not possible). I have seen some pics of other systems where is appears the rad is mounted on spacers of some sort on the top of the case (laid down lengthwise), about 1 or 2 inches above the case, with the fans underneath the rad pointing up. In this case, have these end user actually drilled a hole in the case to match the fan screwholes in the fans and is this hardware that you can buy at the local hardware store?
Anybody have experience with this? Before I go drilling holes in my stacker I've love to get some feedback on mounting a monster rad like the 480. lol
Thanks.
Thanks.
