officermartinez
- Jan 21, 2006
There sure are plenty of Mountain Mods cases out there in cyber-land. 99% of them are pretty huge! However, the Mountain Mods Plateau case seems to be one case that doesn't get a lot of press. It's smaller as I plan on using it as HTPC / Gaming Rig. I'm starting this thread in hopes that other MM's Plateau owners / admirers can chime in with their two cents. Although the Plateau is "hyper modular" like the rest of the MM's line, it's a little different from the rest. I just received my order today from MM's and after unboxing it, I was glad to see it was not damaged during shipment. I was particularly impressed with the fit and finish of the black wrinkle powder coat. I purchased several hex mesh fan grills from coolerguys.com and I've already started installing them. I also purchased some new 120mm fans, which I received a few days ago. During the down time, I took the liberty of sleeving the fan wires. Also, I drove down to my local home improvement store (Lowes) and purchased several tiny packages of black 10-24 x 1/2" socket head cap screws. They will be the screws that I use to mount my 120mm fans.
My entertainment unit in my bedroom is black (as well as all of my peripherals), so this case will fit right in. I'm using my current setup that's in my Antec Nine Hundred Two case with a few exceptions. Now that I have my Plateau case in, I am changing out ALL of my case fans. I purchased 8 different ones (Coolermaster, Antec, Xigmatec *currently installed in my Antec case*, Scythe, Thermaltake, Enermax, Aero Cool and Silverstone). Since I had to purchase a total of (8) fans for my Plateau case, unfortunately, cost played a role in my decision. But, alas, I was happy with the decision. Rated at 19 dB's, the most cost effective, price to performance to audible fan I liked was actually the one I thought I would hate the most.. COOLER MASTER. Seriously? What tha.. bleep! It's not the best fan I've ever owned, it's not the quietest fan I've ever owned nor is it the prettiest fan I've ever owned (but definitely not the cheapest fan I've ever owned.. haha). It just seemed to fit all of my current needs.. Cheap enough, quiet enough, powerful enough.. It even had 5 out of 5 eggs on Newegg. Anyway, let's more on..
I guess I can start with my setup. Like I said, I am already up and running in my Nine Hundred Two case. So, I'm just basically migrating everything over to the Plateau case (with a few exceptions).
Intel Core i7 2600k (overclocked at the moment @ 4.8ghz)
Asus P8P67 Deluxe motherboard
Promilatech Megahalems CPU Cooler (with a dual 120mm push / pull fan setup)
(2) Western Digital Black SATA 6.0 GB/s 1TB drives (RAID 0)
Gskill Ripjaws X DDR3 1600 4x4GB's (just installed it today)
Sparkle GTX 580 video card (just purchased another Sparkle GTX 580 from a [H] member and it should arrive in the next few days. Will obviously be running SLI)
Enermax Galaxy 1000w PSU (old faithful.. still kickin after 4 years of service)
I picked up a Vantec hard drive cooler and I intend on using my LG bluray internal optical drive. While I was at it, I bought an internal USB 3.0 PCI bracket / internal header to give me a couple of extra USB 3.0 slots. I intend to connect many of my fans to a MOLEX to multiple 3 pin fan output connector. I picked a few of those up from performance-pcs.com. I've taken a few pictures here and there and will post them up in the near future.
