Mountain mods alternative?
Chevyman03
I currently have a watercooled cm stacker case that is just to tight for all the stuff I have crammed in there. I really like the MM cases but they are pricey when you add up all the extra's you need. I wanted to know if there are other cases out there that can give me more room than my cm stacker?
I got 6 HD's and a 120.2 rad. I would like to ad another and or bigger rads and more HD's. Things are just to tight in the case. I have a couple HD's I can't get in.
Since I have a 120.3 rad I can feel your pain. Do you have any of the 4 in 3 hardrive adaptors that go with the stacker? Newegg also has a 5 in 3 sas/sata with sliding trays that can save some space.
Corsair 800D? I have 4 HDDs and 2 optical drives in mine right now and I could easily fit a 120.3 and another 120.2 (probably) and still have room for like 3 more HDDs not even including the 5.25 bays that you can get adapters for. I have 3 of those free. So, 10 HDDs, 2 optical, 120.3 and a 120.2 seems like enough room for just about anyone. It is a little expensive though, but oh well.
It's only money. ;)
It's only money. ;)
Ya it is, and last time I checked which was right before I bought my 800D (2 weeks ago) MM cases are quite a bit more expensive once you get everything you want in it. That is the upside and downside of the MM cases, you can add just about anything you may need, but it gets terribly expensive.
Yea I got 4 HD's and 1 ssd drive cramed in the HD cage. Just no space to play with having a gtx295 in there. I got the pump mounted to the bottom of the mesh screen. I mounted the mesh screen upsidedown to give me a bit of room. The case I want is the extended Ascention 24x24x18. Whats scary is when I configure it the way I want it cost $540 plus some extra's and shipping make it over $600+. I wish they would have a sale or discount code to help out. I can't imagine with the way money is now they are selling specialty cases to fast.
The corsair is about an inch bigger than the CM stacker I have now.
But it's set up so much better than your Stacker is. None of the HDDs would get in the way of your 295 because they are in a separate compartment all by their lonesome. I just think that MM cases are way too expensive for the current worldwide economic conditions.
