Motor in disk drive gone bad?
sn66
I've got a Samsung SH-S183. I haven't burned anything in a month or so, but I really needed to burn something today. Hell, I haven't even put a disk in the drive in a while. I searched around and there is nothing to be found. My bios and Windows both recognize that my drive is indeed plugged in, so it isn't "dead".
However, I took the casing off of the drive, just to see what exactly is going on inside when I start up my PC. The laser will move, and the disk will spin in two very weak bursts, then stop. I bought it OEM about a year and a month ago, and I probably am just reaching for a solution here other than buying a new one, but it doesn't hurt to try.
Looks like either the drive circuit, the motor, the signals to the drive circuit or reading of data is faulty in some way.
I cant see an easy way to test/repair unless you are into electronics and prepared to diagnose surface mount circuits and signals from chips.
New drives cost so little now its not worth the trouble unless you want to take on a project.
