Motion Blur
Odellus
iirc all of the korean single input monitors have no overdrive so the motion blur is very bad. VA televisions are also quite bad but they have overdrive, so the motion blur should be similar if not better.
if it says semi-gloss you can believe it. the vast majority of tvs today are semi or full glossy.
icor1031
I can believe, but what is it?
