Motherboards keep dying
Stuh505
Upgraded my system, got a new PSU, processor, RAM, mobo, and vid card.
Using a CoolerMaster 450w psu, dual core 3800+ proc, 4 gigs of rosewil, msi k8n neo2f mobo, and quadro fx 3000 card.
Off the bat, things were funky...it would freeze after being idle ofr about 30 min, or right away if i tried to do anything graphical. would do this using my old geforce card too. After locking up about 100 times it finally just stopped working entirely, also did some damage to the sound card and video card but they still seem to work for the most part.
Using my old P4 and motherboard, these problems did not occur.
My old board wasn't perfect, I had had a couple problems in the past with it starting up. After using this setup for about a month while my new board was RMA'd, my old board went belly up. Wouldnt even load the bios.
Got another brand new msi board, same specs. Same problems!! So this is now the 3rd motherboard that's died on me in 2 months.
It is constantly freezing up esp when I try to do anything graphical. Happens with both vid cards.
I have been using the same PSU during all these problems, I measured it with DMM and I get 12.26...that's only 2% off. But perhaps it fluctuates or something...I should try using the old PSU.
Now that I've got 2 different boards by MSI and they both cause this problem....I am thinking, maybe the MSI board just isnt compatible with nvidia cards? But that sounds kind of crazy because there have got to be a lot of people using these both...
Heat...
Try remounting your heatsink... make sure that thing is snug on there and flat and make sure you either use some good paste, like arctic silver 5, or the default that comes on the stock hsf.
The first time I used the default thermal glue that came on the new processor....on my new board I used arctic silver, theres no problem there
Well it could be the motherboard or the CPU, the motherboard is cheaper to replace so I guess that's what I should try first.
What is the most reliable motherboard I could use for this configuration? ASUS?
My old socket A mobo was MSI, that thing gave me no end of problems. It's now a wall decoration :p
