Motherboards for Intel Conroe
mmarsh
Hi
I'm thinking of moving my DFI and 3500+ to my 2nd PC and getting a Conroe Processor
for my main pc. I havent used a Intel MB in some time, whats good out there. Do I have to use a special type of MD for Conroe or will any LGA775 work?
There's a lot already out there on this issue...just browse around ;).
Not all LGA775 boards will work. You need one based on the 965/975 chipset from Intel or just look for ones that say Core 2 Duo ready. Not all 975X chipset boards will work either, but all 965 boards should work. The ATI/Nvidia chipset boards supporting Conroe are not available yet.
Sorry I guess I didnt look closely enough.
Just one more question, of the 965 and the 975, which is the most recent chipset?
965 is most recent. The 975 is usually found on more "high end" boards though.
The Intel D975XBXLKR AA revision # ending in -304 will work, and are conroe ready. In fact, I've been playing with some at work, with some OEM Conroe processors and its hella fast. If you want to buy the D975 conroe compatible board, PM me. We just got ours in at work last week.
edit: The D965 board is to the older D945 boards, like the D975 was to the discontinued D955 boards.
