motherboard
ihave this set up right now.
AMD Dual Core 270 3.4Ghz - Gigabyte 880GM-USB3 HDMI Motherboard - 8GB DDR3
http://www.amazon.co.uk/AMD-Dual-Co...BCEQ/ref=sr_1_2?ie=UTF8&qid=1322687550&sr=8-2
but i would like to know what hard drives will work with it?
(T2000DL003 Barracuda Green 3.5-inch 2TB SATA 6 Gb/s Drive (64MB Buffer,5900RPM)
if that one works?
or what does the SATA have to be?
sata II
sata III
+ thinking about buying a Antec Performance Max Coolerfor Intel Socket 775 and AMD Socket AM2/AM2+/AM3 would this cooler work?
Any SATA device should work in any SATA port. The speed will be negotiated by the lowest common denominator. In this case, your LCD is the sata 1 port. So your max speeds will be at SATA 1. It would be cheaper probably for you to get a SATA 1 drive instead of a SATA 6Gb/s drive. However, if you already have the drive, it should still work, just not at its fastest speeds.
