Motherboard Temps
RussianHAXOR
My Cpu is running at 32 Idle and my motherboard is running at 45! Whats up? I just cleaned out the Fan on it and dusted it off completely and i still have this problem. Should i install a Zalman 9500 on the Mobo too? :D
I have a similar problem on my second computer. I know if I add a chipset fan on the northbridge, the problem would be solved.
I'd put two on :p
That is a big gap ( at least to what I'm used to ) between cpu and board.
Mine is cpu 27/29 board 32
Why should i put on another cooler? The fan worked FINE until recently... like i mean i was getting MUCH lower temps like 28C.
Are you using speed fan to monitor and if so did you just update it, cause I know have temps that are jacked up with the new speedfan.
