motherboard temp threshold?
NightLinks
Hello,
Is it safe for me to raise the threshold of my motherboard in ASUS Probe? Right now temps are processor 38 C and motherboard 37 C everytime I play BF2 asus probe warns me that the motherboard threshold was reached 45 C. The processor threshold is set at 65 C default.
I was wondering if it is safe for me to raise the threshold to 50 C
Hello,
Don't set it to 50, might as well stop using Pc probe II. 45C for your mobo temp is on the hot side. Hows your air flow in your PC case? You may need a better PC case for better cooling, what case do you have? You could always point fans at the mobo to cool it.
I have a Apevia X-Superalien case. The normal temp is like 36 C - 37 C the threshold was from PC Probe.
