motherboard temp high?
port-error
I'm having this real odd problem. About 3 months ago, I had a surge that effected my power supply. That in turn killed my hardrive, floppy drive, and cd-rom. I replaced the power supply, cd-rom, and hardrive and everything has been working fine for about a month now. I recently installed motherboard monitor, and got alarms right away. My cpu temp is only 38C, but it reads my motherboard temp as like 180C? I thought maybe i configured mbm wrong, so i went into my bios and looked at the motherboard temp, and omg it was 180C. I couldn't believe my board was that hot so i shut it off and felt inside . It wasn't, i would think it would be on fire if it was that hot.
I have two suspicions, first my bios update, i wasn't sure if i had an A7N8X-dlx reversion > 2.0 or a reversion lower than 2.0. How can i tell this? I bought this board last year. I believe i updated my bios to a reversion > 2.0. Could that be the problem? Also, is it possible to RMA this board through ASUS? and does this seem like a serious problem or just a bad temp probe?
It's probably just a very very messed up probe on your mobo. If you can I'd say get a temp probe and see what your real temps are just for your own sound mind.
