Scorpionjwp said:I am drilling hole in a case I am modding, drilled the hole too big on a few standoffs, not sure of the drill bit size to use, or tap to use to thread these holes. I tried to drill the hole, tap the hole, but it seems as I put the standoff in the threaded hole, it turns and turns, then never gets tight.
eyedol said:I'm in the U.S. so I just used google to find it.
http://www.maplin.co.uk/ On the left nav bar search for "m3 standoff" It's like the 4th one down.
Site has frames so I can't link you directly. Those are 4mm though. Do you really need the 8.5mm ones?
Jeez...the only 8.5mm ones I found were here. Couldn't find them at any other U.S. store unless I totally missed them. I think they take international orders...
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?sku=U10-3004&SRCCODE=INKQUIGO&CMP=KNC-INKTOMI
The 8.5mm ones seem kind of rare.![]()
T01-WIRE :: 25 DOLLAR WIRE TRANSFER FEE 1 $25.00
UPS Worldwide $48.40
boycee said:Perhaps not.....
$8 worth of components, and the rest is charges.
Well never mind, anyone in the US fancy doing me a small favour?
Cheers
