Motherboard Standoffs
spydermonkey
I'm having some trouble finding some motherboard standoffs for an old case of mine. They're not the regular screw in type, but the clip in type. I've looked all over, but I can't seem to find any place that sells replacements. Anyone know where I can find these? :confused:
Do you mean the plastic clips? I seem to remember getting a bunch at compusa a long time ago...
No, they're little square shaped ones that pop into the motherboard tray. The ones I've used on other computers with the same setup are made of metal.
I think what he is looking for are the plastic pressure clips that come with some of the cheaper cases. They are small and square with a screw hole in the top.
I wish you lots of luck, you best bet is to go to your local comp shop and see if they
have any from a colors it case or something along those lines.
google pc case fastners or pc case screws. There's a guy in Florida that specials small screws and the like. I looked everywhere for my receipt from him but I cant find it. I got all sorts of weird MB hardware from there about 6 months ago for about 20 dollars.
Try this: cnaweb.com
