Motherboard SNAFU
dc_firedrake
Quite sometime ago a diod (or something of the sort) 'poped' on my old motherboard consequentially "shorting" out my disk drives, my HDD, and my GeForce 4... I was wondering if it might be possible to fix my motherboard... or any suggestions?
Motherboard:
Close up:
Pretty much the same deal with my graphics card.
I can't see how that would have shorted out any other components. What makes you believe that is the case? Did you install a new motherboard and the other components won't work? What is the deal with this?
More information is needed to answer your questions.
Well this happened quite some time ago...
After sparks came flying into my face I immediatly cut the power... of course. Then I switch motherboards and proccessor to a Tyan Slot 1 PIII board. My 40 gig HDD was non responsive. And my GeForce 4 also had a short on it as I discovered after words (it still works... it just produces a blue hue over everything now). Then my CD-RW and CD-ROM drives were also non responsive. They worked before I shorted my board and despite my countless efforts to get them to work they remained inoperable.
