Motherboard settings can't be changed?
RadDad
Bad Trader
I have a friend that has a HP. It has the Asus a8ae-le mainboard with a stripped down bios. Is there some software or a way to reflash the bios to get rid of the HP bios? Or is there software that we can use to change the settings? Memory timings,video memory,FSB, etc? The board runs great but we cannot change many of the settings.
Specs.
X2 3800+
A8AE-LE (ATI RS480 chipset w/400 SB)
1GB Infereon Memory
X800XL
Audigy2
They have crippled BIOSes. Unless you can find a hacked BIOS file, I doubt you'll be able to replace the HP BIOS with a standard ASUS BIOS. As a matter of fact, if you search ASUS' website, you'll probably find that they state this model motherboard (A8AE-LE) as an OEM motherboard, and you should contact that manufacturer. HP *MAY* have hidden BIOS settings (ie: hotkeys to activate), but you'll have to contact HP tech support on that one.
Good Luck
P.S. Tell your friend to "build his own" from now on... and he'll have full control of the BIOS.
I figured that. I did a google search and there are quite a few people who have these boards. It seems to run stable and is fairly quick, he is wanting ti diable the onboard graphics and tweak his memory timings. I'll do some more searching though. Thank you.
