Motherboard scratched....
Rydawg5143
I have a ep35-ds3l. When i took everything out to RMA the board i scratched the bottom where the cpu retention bracket was ( under the cpu) cause I was retarded and took off the paper that exposes the sticky tape..... Anywho. Gigabyte sent it back and wont repair it cause scratches....
I took out the ds3l in favor of a ds3r ( im dumb) about a month ago and ds3l has been in a box since then. I was going to RMA it cause i was gettign bios resetting ( see another of my threads on external hard drive = the suck)
The problem i get is endless reboots. It turns on and tuns off then back on etc, it stays on and all fans spin up etc. It doesnt get to any screen or anything. I didnt get this before I took it out of the build..
Would the scratched on the bottom really effect it like this? Never had any 'broken' hardware so i dunno if it is the scratches or if perhaps its something else.
Oh, ok, your wording had me confused. It looked like you were saying you sent it in, and then after that you've been waiting to RMA it.
Ok.
Anyhow, yes. If you hit the traces they can short on each other or sever causing it to reboot, no power, or no post.
traces are the little signal/power lines that run all over the motherboard. they look like little lines.
if you just scratched one, it may be somewhat easy to fix with a little bit of solder, but if you hit multiple ones that are in close vicinity, you're pretty much screwed.
Thanks for info.... yeah i severed like 5 of them. Lesson learned i suppose. sodering isnt an option as i dont have the tools or the knowhow /
