Motherboard RTC (Clock) Running Fast
Format _C:
I normally don't care about the system time on the BIOS/CMOS/Windows but the clock in my HTPC is constantly about 3-4 Minutes fast and that means my recording Schedule is getting messed up. I have been compensating for it by padding my SageTV recordings but that is getting old and does not always work(Especially for back to back recordings) and I am looking for a real solution
My HTPC Specs are as follows
GA-73PVM-S2H
E2200
2 X 1GB of DDR-II 800
Seagate 500GB SATA 7200.10
Lite-On SOHR-5238S
NEC ND-3550A
Hauppauge HVR-1800 OEM Whitebox
Microsoft Windows 7 Ultimate 64-Bit
MCE Remote Receiver but using a Harmony remote with it
SageTV V6
Cheap Generic PSU until I get my Antec Earthwatts EA-430 from the 'Egg on Monday
I have a program I am using to sync the time with the NTP time servers called Dimension 4 and I have it set to do sync every 15 Minutes and when it does sync it almost always is subtracting about 4 minutes from the system clock each time so I need suggestions on things to check/do I am not using the Windows Time server Sync option as that will only do it every couple of days and by then I will have gained about 20-25 Minutes
I remember this happening on my SKT 939 MB years ago (Nforce 4 Asus A8N-E) so is this a chipset problem? or a motherboard problem? I need this to be fixed ASAP
I have another Gigabyte board I am using (GA-G31M-S2L) and that does not have the problem and that used to be my HTPC a couple of years ago and it worked fine
Thanks
I think I am having a different issue any other suggestions?
Could be a bad oscillator, bad RTC, bad battery. Replace the motherboard if you can. You can try flashing a new BIOS.
it turns out the clock was fast in the BIOS by about 4 Minutes so that's why my program was subtracting 4 minutes every time it synced with my time server. I feel like an idiot but I always thought the OS changed the BIOS clock to match what the OS time was and not the other way around Oh well all is good now
