This is my father's computer, by the way, so i'll try to be as specific as possible.
Here are the specs:
Abit KR7A motherboard
AMD athlonXP 1800+
I dont know what kind of Vid card, or sound card or ram, but i dont think it matters much..
Heres the problem,
The computer will show the post screen, where it shows "hit delete to enter setup" Etc... But doesnt do anything past that. No startup check, no memory check. It simply freezes up. You cant hit enter to go into the bios and the optical mouse doesnt light up upon boot. It beeps, and does nothing after that. We tried swapping keyboards to hit delet to enter the bios. No luck. Tried resetting the jumper pin to reset the bios. NO luck. Tried taking out the battery to the mother board and let it sit overnight. NO luck. Nothing was done to the computer except turn it off and move it from one side of the room to the other. It wasnt bumped or anyhing and everything seems to be seated well into the motherboard.... I dont see how anything could have been fried in the process of moving, when the case was never opened up. I think the motherboard is FUBARed, but i cant seem to find why it just decided to up and quit one day. Possible lightning strike? But if that were the case, wouldnt the rest of the elctronics in the house, or the monitor, etc be fried as well?
Any suggestions on furhter things to check?
Here are the specs:
AMD athlonXP 1800+
Heres the problem,
