Motherboard Reccomendations
TheBandit
Can anyone help my choose a motherboard for my 1.6 Northwood? Is anything even being manufactured for a chip this old? I wanted a new MSI 845 Ultra but I found out they are discontinued. Any suggestions?
Manufacturers have been phasing out the old i845E and i845PE motherboards. Of the current motherboard chipsets out there, since your particular 1.6 is a Northwood, and runs on a 400MHz FSB, your best bets for motherboards (using an Intel chipset) are those based on the i865PE, i865G and the new i848P chipsets - the latter is simply an i865PE modified for single-channel-only DDR support. Only the top-of-the-line i875P doesn't officially support the 400MHz FSB.
Oh, I looked up Abit's Web site. That BH7 is based on Intel's soon-to-be-phased-out 845PE chipset, which (officially) supports DDR333 (PC2700) memory.
the 865PE Chipset supports ALL northwood processors. No intel chipset will let you run anything faster than DDR266 w/ a 400 FSB processor, to use DDR400, you must get that sucker up to 3.2.
