Motherboard Reccomendations :)
It would be nice to keep a budget under 150 dollars but this is my gaming PC so money isnt too much of an issue.
Setup:
Q6700 w/ Thermalright Ultra-120 HSF
4x1gb Crucial Ballistix 800 @ 950
Corsair Memory Cooler
EVGA 8800GTX w/ Stock Cooler
Thermaltake ToughPower 750W EPS12V
2x Raptor 150gb RAID
Seagate 7200rpm SATA 320GB
Samsung DVDDL SATA Drive
Coolermaster 690
3x USB Exteral HD
Memory Card Reader Built into Dell 2407wfp-hc
Logitec MX Revolution
Currently PS2 Keyboard b
Need:
Great Overclocking Potential
Great Reliability & Customer/Technical Support
RAID0 SATA Support
Great Stock Chipset Cooling
Easy CMOS Reset Capability
Advanced BIOS Overclocking Features
Compability with Corsair memory fan cooler
Want:
Active(Fan) Stock Chipset Cooling
Onboard BIOS LED error display
Great Onboard 5.1 Surround
Solid State Capacitors
Yorkfield Compability
Fast Startup Times
Dont Need:
SLI
More than 1 PCIe 16x
DDR3 Support
Chipset watercooling capability
Firewire
eSATA
IDE support
I am hoping to get a 400x9 overclock which brings up another question. What does it mean when it says the motherboards and processors support 1333? Does this mean they can run at something like 667x5 instead of 400x9?
Why would the only difference between a Q6600 and a Q6700 be the 9x vs the 10x multiplyer if the Q6700 is a better processor? What would be the optimal overclock for a Q6700 with the best memory avalible?
I will be watching this thread every day so feel free to ask any more qualifying questions that I missed.
Thank you for reading :cool:
you may be asking for a lot. finding a mid-range board that overclocks well, supports 1333fsb (perhaps a necessity for yorkfield), and has only one pcix16 slot might be nee impossible. the closest type of board the would conform to your constraints is the p35 based boards. if you absolutely, positively, must have a single video slot, then your only choice is to go with the g31/g33 based boards. unfortunately, i've not heard of a single case of these boards overclocking beyond 350fsb.
When I say "Dont Need" I guess I should have stated that it is not necessary..... If I have to have a second PCIe 16 slot than it is not a huge deal I just didnt know if there was another option.
Right now its looking like an IP-35 Pro from Abit is there anything else I should be looking at? I dont know if the chipset cooling is going to be good enough for me.
Is there better boards out there for my needs?
The slightly more basic & cheaper abit IP35 would cover virtually all your needs (it doesn't have an external clearCMOS switch but you can rig a cable & switch to the header pretty easily if you want to) & a good few of your wants.
" What does it mean when it says the motherboards and processors support 1333? Does this mean they can run at something like 667x5 instead of 400x9?"
Intel's quoted CPU fsb is 4x the "true" bus speed as it's a quad-pumped bus i.e. 1333fsb CPU's run on a 333fsb bus.
"Why would the only difference between a Q6600 and a Q6700 be the 9x vs the 10x multiplyer if the Q6700 is a better processor?"
It's not, it's the same CPU just configured to have a max CPU multi of 10X rather than 9x (possibly better binned too but I haven't heard of a Q6600 that won't do Q6700 core speed). It's inefficient to make 2 different parts if you can make 1 & just adjust something (bridges) on it to create 2 SKUs.
IP-35e went up on ebay.... probably will bite on the Pro version off of newegg.
I want the pro version vs the standard abit ip35 becasue it has an extra heatpipe on the chipset :) uGuru is nice also
And in response to BUFF what would an optimal overclock be for a Q6700 with the best memory possible? If I had DDR1333 memory I could run it at 667x5 (3.4GHz) and it would be faster than say 378x9(3.4GHz)? I should be going for the lowest multiplier possible with still acceptable CPU clock speeds? I can hit about 3.4GHz at 10x, 9x, and 8x currently with stock HSF.
I have read that both all memory should be run at 1:1 and that Intel processors actually can take advantage of running at more than 1:1. I understand the memory:fsb concept but I dont know which is true.
Thank you [H]ard|Gawds
Check out the Overclocking Intel CPU Sticky at the top of the Overclocking forum - read it through, twice if you have to. Wealth of information in that post.
As far as board goes, the 780i chipset XFX board runs great now that the new bios (P02) is out - increasing stability for 1333mhz procs. I'm using a 1066mhz Q6600 B0 revision, and I hit 1333mhz (333x4) immediately (2.4ghz to 3.0ghz at 9x333) - then switched over to 1600mhz and just finished up 15 hours of prime 95 stable at 3.2ghz (8x400) at 1600mhz (400x4) - with ram timed at 1066mhz (3:2 divider) - all on air. Can't wait to see what it'll do when I get blocks on the MCP and SCP.
Not too many sticks of DDR2 at 1300mhz stock - most seem to cap at 1200, though newegg had some teamxtream that was supposedly 1300. Not that you can't overclock your ram - just urging you towards examing if you want a DDR2 or DDR3 mobo - DDR3 prices are steeper, but their clock speeds are rated higher.
you don't need DDR2 1333 memory, remember what I said about Intel CPU bus being quad pumped so that 1333fsb was really 333?
Personally I'm a fan of using the max multi (you paid for it so use it ;)) so for 3.4GHz you would just run 340fsb which would require DDR2 680 for your RAM at 1:1.
Running the lower fsb should also be less stressful for everything on the motherboard.
You can run RAM faster but almost certainly at the cost of eased latencies.
You could drive yourself mad testing every possible configuration of multi, CPU:DRAM ratio etc. & I don't hink that you would seee much more than a couple of % points difference in performance.
3D apps would probably show some benefit from higher fsb though I would expect & that may well include gaming.
