I have just about given up with my MSI Nforce 2 motherboard (K7N2-L). I had one stick of crucial 333MHz RAM in the board (512) and decided that I wanted to add a bit more. I thought that I might as well get some Corsair RAM as It is supposed to be high quality stuff.
I tried the new RAM (2x512) in the computer and the damn thing just would not get into windows, it would boot up then it would try to load and just reset. Thinking that something must be wrong with one of the modules. So I tried one and it posted as something else (512 of 400MHz RAM, not 333Mhz). The other stick I tried did not even work.
I thought this was ok as it must be some bad RAM (annoying as I thought this paired Corsair RAM was supposed to be hight quality!). I sent it back and instead of a refund I swapped it for a 1Gb Module of Major Branded memory (I guess you could call it the cheap stuff but my other PC has 1Gb of it and it is superb. I HATE paying loads of money for RAM when basically I think that its mostly just the fancy name you pay for).
I tried the new module of RAM in my computer and this damn thing would not work! It loaded up and would just keep restarting!
I give up with this motherboard, i'm gonna spend £50 on a new motherboard as I cannot swap the RAM again as it seems to just be a very picky motherboard.
Does anyone know if either Asus A7V600-X KT600 or Abit KV7 KT600 have any issues with RAM?
I just want to be able to use 1x512Mb Crucial DDR333 and 1x1Gb of Major RAM with no issues.
Thanks very much.
Thanks very much.
