Motherboard RAM Help MSI
HellStinky
Hey everyone I recently bought parts for a new build and all was working but the RAM. Now Ill start by saying that I was having trouble with the monitor getting no signal till I switched the ram from slot 1&3 to 1&2. So I tested all that slots and it seems that slot 3&4 are not working whenever I plug them in my computer wont send a signal to the monitor. If I put the RAM in slots 1&2 it will get a signal and run fine. I was wondering if anyone can help me out here the mobo I have is a (MSI Z87-G41) and the RAM I am using is (Corsair Vengeance Low V. 1600DDR3 (4x2) 16GB)
Yeah well the BIOS update was pointless came out to be 2 out of 4 were DOA :(. But thank you for the help.
I'd be more suspicious of the motherboard's CPU pins than I would getting two DOA RAM modules. Did you replace them already?
Are the RAM modules all from one 4channel kit? If not, that's probably why they don't want to work together. RAM is binned and put together with compatible modules and may not work well with other modules of the same exact type from a different bin set.
Pfft RAM is not binned, unless explicitly said as such (and even then I doubt it).
DIMMs in kits are just random DIMMs in kits. Whether you have 2x2DIMM kits or 4x1DIMM kits or a 1x4DIMM kit, all those DIMMs came out of the same exact pile and none are better suited to work together than the others barring random lemons.
What slots does the board prefer RAM in? It's not always what you would think and it's often buried in the manual some where. I've had ECS, MSI, and GB in the past that wanted slots 1/2, or even 3/4. Doing dual channel the traditional doesn't work because of how they made it. It's mad stupid and defies all logic, but it's not uncommon.
