Motherboard questions
PNut12345
Putting a new build together, first one in about 4 years, and I've got just a few questions:
1. DDR2 or DDR3? I plan on mainly gaming, surfing, and maybe some video encoding stuff. Is the DDR3 worth the price premium?
2. I plan on an intel quad core. What's the best chipset out right now. I'm seriously looking at SLI, too. I believe the SLI part rules out any of the new AMD stuff. It's just so convoluted now: Intel supports Crossfire, a competing part from AMD/ATI...?
Thanks in advance.
Edit: just to clarify: I'm looking for fast, stable and good value. E-penis size is not an issue and I don't need the latest cutting-edge, soon to be outdone parts. I'll be running Vista 64-bit.
I'd like to spend < $200.
1. No
2. given your budget probably an Intel P35 based mobo.
You aren't going to get a quad CPU, new mobo & DDR2 for <$200 so I hope that's the budget for the mobo alone ...
if you really want/expect to run SLI (& remember that we have already dual GPUs on single cards) then you are restricted to an nVidia chipset of which 790i would be best but of course the dearest option ...
If you're going to be doing video encoding, you'll want to go with a Penryn as SSE4 brings a good boost to video apps that have been SSE4 enabled.
As for the price premium of DDR3, just remember that DDR2 is going to die pretty fast once Nehalem comes out as it will only use DDR3 with its integreated memory controller. But DDR2 is still fine.
1. No
Yeah, $200 for mobo alone. Sorry, should've clarified that part...i'm looking pretty hard at the evga 750i FTW mobo...guru3d couldn't say enough good things about the board.
