Motherboard Questions
alaracon
I figured I would ask some questions about motherboards in my first post on these forums. I am planning to build a system around May-June of this year that is based off of an Intel Quad Core Q6600 processor and 4GB (2 x 2GB) of either 800MHz or 1000MHz DDR2 memory. I have done a lot of research and looked at many reviews but it just keeps increasing the list of possible good motherboards.
I currently have two systems running off of the ASUS A8N-SLI motherboards for AMD processors. They have run great for several years now so ASUS is definitely a step ahead in my book for motherboards.
I have looked at various motherboards so far but the list of possibilities includes:
EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard - Retail
ASUS Striker Extreme LGA 775 NVIDIA nForce 680i SLI ATX The Ultimate Gaming Motherboard - Retail
DFI LP UT P35 T2R LGA 775 Intel P35 ATX Intel Motherboard - Retail
XFX MB-N780-ISH9 LGA 775 NVIDIA nForce 780i SLI Intel Motherboard - Retail
ASUS Striker II Formula LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard - Retail
I do know that I would like to have a board that supports SLI but beyond that I don't know for sure if I want something with the P35 chipset or something with an X38 or X48 chipset. Any advice or suggestions would be greatly appreciated.
Most of the motherboards listed above have gotten pretty solid reviews.
hands down
dont bother with nvidia chipset, unless SLI is one of your wishes
Intel chipsets, like P35 and X38, are better in almost every way than NVIDIA chipsets (for Intel processors). Just so you know though, you can't use SLI with an Intel chipset, so if you want SLI, then you must get a board with a NVIDIA chipset. Sorry if you already knew this, but your post implies that you definitely do want SLI, but want it on P35. It ain't going to happen.
I think a lot of people here will tell you it's better to get an intel X38 or P35 chipset and 1 expensive card as opposed to nforce and 2 cheaper cards.
Unless one is using a monitor with a 1920x1200 resolution or above (and even at 1920x1200 it depends what you play), I would concur there. SLI generally just isn't worth it except at very high resolutions.
I think by May/June a new Intel chipset is going to be out, so you might have to start your search all over by then :) Hopefully someone can confirm.
P45 should be out very soon now, though nobody knows just how soon. Could be anywhere from the end of this month to the May/June you said. That's probably what you're thinking of. After that, just chipsets with integrated graphics cores (e.g.: G43), that most enthusiasts wouldn't be interested in. And henceforth will die Socket LGA 775. ;)
Then very late this year, around November/December, Tylesburg will ascend bringing Nehalem to those with deep pockets, as only the server parts and the Extreme Edition will be out first, while the rest of us have to wait until sometime in 2009. There will actually be 3 separate sockets for Nehalem: LGA 1366 for single-processor servers and high-end desktop CPU's, LGA 1160 for midrange CPU's, and LGA 715 for budget CPU's, with integrated (into the CPU!) graphics. All this info is from Beyond3D by the way.
Alright, updated template going with suggestions I have heard here. Most of you really do sound like you think SLI isn't worth it unless you are going with multiple monitors and such. Right now it looks like:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail (might go with DDR2 1000)
EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Does that sound better to everyone here?
If I was going to go with two 9600 GTs instead of the one 8800GTS...what SLI motherboard listed above would you suggest?
In May-June P45 will probably replace P35.
You are best asking when you are ready to build as too many new mobos/chipsets will come out over 2-3 months.
Good point, it also depends on pricing in 2-3 months. Prices usually go down quite dramatically when new technology hits the market so the whole system may change over time. The other parts have been easy to figure out so far but the motherboard and video card keep changing in my configuration.
I was about to ask the same question alaracon, as I'm in nearly the same situation. If SLI isn't really worth it, I'm not going to bother.
