Ok so here is the rundown. I bought an e8400, zalman 9700, 4gig G-skill ddr2 8000, 2 250 gig 16mb cache SATAII HD's, Xclio windtunnel tower, 700w psu, 9800 GTX, and a GA-X48-DS4...All from new egg.
I spent probably 4-5 hours putting this new rig together maticulously... I wore anti static wrist band and had it grounded on the case, I wore none latex gloves with no powder.
After everything was together and tied up with plastic strip ties, and I had followed the install manuals to a T and double checked everything with my second PC online. I went to power on and absolutely nothing happend. as I pulled the 24 pin ATX out of the MB the lights flashed for a split second and the fans sped up. So I pushed it all the way back in and nothing. So I pulled the 24 pin atx so it was half way plugged in and everything went at full speed but the motherboard would not boot into bios. "I did that for maybe 10 seconds" then I dissasembled the whole PC to see if I had a short with the case. I set the Mb on a none static bag and hooked it up to 1 HD the vid card and a DVD rom. Still nothing if I pluged the 24 pin atx all the way in. So I pulled it to half way and the lights flickered and fans spun really slow this time.
The light indicator on the MB was flashing short fast beeps "mind you the 24 pin plug was only half way in the slot, if I put it in all the way nothing would work, just a dead PC". When I referenced that to my manual, it meant I had a power issue... So at first I thought it was the case wires that were not plugged in correctly, then I thought the power supply was broke so I bought a new one and tested that. After fruitlessly working on this thing for 2 days I decided to RMA the motherboard back to newegg for replacement.
Any imput you guys have I would much appreciate. I cant decide if I should get a new MB or what even happend here...
Thanks gents
Thanks gents
