Motherboard problem???
Mekanic01
My comp died about a week ago, and I haven't had alot of time to deal with it until now. When I tried to start it back up, the power light would go on as I hit the power button, but would go out almost immediately. I thought at first that it was the power supply, as it was just a used backup that I threw in when the last one died. So I tossed in a new power supply, and it did the same thing. I tried switching cords, changed outlets on the surge protector, checked all my connections.
I can only assume that it's the board, and that if it was the cpu it would fire up at least to the bios, right?
every situation is different, but it sounds like the board. I just had a similar problem at work. I was able to swap out all the parts with another, identical PC and the only component left was the board... Replaced it and put all the other components back in and it worked like a charm...
