Motherboard Problem ?
Mixman
I just put my old system into a new case. It did work for 6 mos together. Now in order to get it started I have to flick th power switch on the psu. It then comes on. Once on it will stay on, but a few minutes after shutdown and I cannot power the system on without using the PSU power switch and then it comes on automatically. The green light on the motherboard does stay on. I checked all of the connections for a short and cannot find one.
Is my motherboard bad ?
Did your case come with a new PSU as well? If so, try using the PSU from the old case. Maybe the case came with a psycho PSU.
Also, you may want to check and see if your the power switch from your case is wired up to the motherboard correctly. Or maybe the power switch is defective. Perhaps its not being de-bounced properly or something.
Other than that, the only thing I can think of is maybe something got shorted out or damaged (static discharge) during the case-switching process.
