MotherBoard Problem --> CPU Multiplier not doing anything
  • Thread starter Deleted member 79192
  • Start date
D
Guest
I recently purchased a DFI NFII Ultra-AL Motherboard. In it, is an Athlon XP 2600+, which I am attempting to overclock. In the BIOS, there are quite a few choices to set the CPU Multiplier at. But, whenever I choose one besides the default (11.5), nothing at all happens. THe core clock speed stays the same, at around 1909 MHrz. I was wondering if anybody knows what it wrong, and if anybody knows any way to fix this. Right now, the only way to overclock the speed of the CPU, is to increase the FSB, which puts the CPU at a risk (the Motherboard and RAM can easily handle up to 125% of the CPU's stock speed...). I would greatly appreciate any advice!
All new 2500+/2600+ Athlon XP's are multiplier locked.
You appear to have a multiplier locked chip. Time to OC your FSB
Or there's a Windoze program called CPUMSR [could be wrong proggy I'm thinking of], I think, that (from my understanding) fools Win into thinking you have a Mobile chip, therefore giving you multi access. The drawbacks that I know of are>
a) only useable in Windoze, not the BIOS
b) involves some sort of trace/bridge cutting and/or joining
c) don't even know/recall if it works w/ NF2 based boards or not
I don't really know the details, and I could be totally wrong on some/all of the points, but google should be able to give you more ideas on the matter if you're interested in trying.
If it were me though, I'd just try and do what the other post said, and bump up the FSB, and if it wasn't good enough grab one of the Mobile chips before they disappear.
And here I thought that locked multipliers only means the only selection for CPU multipliers is the default... DOH! Why didn't I go with the 2800+?! Now how am I supposed to overclock the thing? Time for a little FSB expirimenting... just hope my parents don't get mad if something REALLY bad happens. I alrdy had to reset the BIOS because of accidentally setting the RAM at double the rated speed, lol.
