Motherboard Panel? - Computer Won't Turn On
GeForceX
Here's what I got...
400 Watts PSU - 3.3V - 24A / 5V - 35A / 12V - 12A
ASRock K7S41GX
Mobile Athlon XP 2500+
Zalman 7000A-Cu HSF
Corsair PC-3200 Value Select
Western Digital Caviar SE 80 GB 8 MB Cache
Plextor 48 x 24 x 48 CD-RW
Mitsui Floppy Drive
It's basically a budget PC (though the heatsink is a funny one for a 'budget' PC) for a friend.
Now, I got it all set up and wired neatly as possible for free airflow and et cetra. Just view the picture below and judge the work.
Now, here's the problem, it's all set up. The motherboard main connector is already in and made sure it was in. A potential problem is the panel (like Power LED, HDD LED, Power Button and Reset). I got the Aspire Case. The Asrock motherboard has those four I just mentioned and some 3-pin Power LED Connector which is essentially the same as the Power LED on the other panel except it has another pin (or I could be wrong). I tend to do bad in this field (just confusing about 'ground wire' and etc...). I got the picture as well below.
It just won't turn on. The power supply is set to 115V with its' power switch on with the power outlet plugged in as well. Everything is supposed to go the way it is (or maybe not). I press the power button. Won't turn on. I tried some changes with the panel but it doesn't make sense to because i am following the directions/steps/diagram in the book. Anyone experienced in this kind of thing, help?
Thank you.
-J.
P.S. Not sure if this is a *general* problem or exactly a *motherboard* problem. I'm posting doubles in the general hardware forum as well.
ok dumb question, is the power supply plugged into the wall recepticle?
Another thing to check is the case switch, is it jammed? it is usually only a temporary contact switch, if it's stuck the computer may not turn on..
Kudos on the install, if you do get it running, maybe swap out the ribbon cables for some round cables..
Later
MD
Pretty basic here.
pins 1+3 for harddrive led
pins 2+4 for power led.........if they dont work right, switch +/- around.
pins 5+7 for reset switch
pins 6+8 for power switch........shouldnt matter what way they are on.
Try unplugging the power switch from the board, and manually connecting the pins with a piece of wire/screwdriver/penny/whatever for a second. If it powers up, the switch is bad.
