Motherboard or ram woes....
Inquisition
Ok so i bought my new computer part by part..
and i also bought this ram 1GB DUAL CHANNEL PC3200 400MHz ELIXIR DDR RAM EBAY LINK
i quickly found out that its incompatible with my abit nf7-s v2.0 in dual channel mode memtest 86 detected A LOT of errors normal mode less errors but errors nonetheless that caused random reboots.
so i ordered this ram GEIL DUAL CHANNEL 1GB (2X512MB) PC3200 DDR400 MEMORY
EBAY LINK
it finally arrived today, to my dismay as i installed it, the motherboard beeped for two seconds and silence..no monitor activity, then another 2 second beep...
I tested the new ram on another computer, it passed with flying colors and then i tried changing it around in different slots... same thing occurs. so i place my first set of incomaptible ram (the elixir) and it wont post!... eventualyl after a few tries it does post and i tried to flash the bios to the new v25 of the abit nfs7 v2.. It finishes flashing from windows and then reboots, but then nothing happens as in it stays blank and wont post.
so i clear cmos and still the same.. Someone please help me with a solution thats best for this problem. im considering eRma the motherboard.. that would cost me $25 + shipping. cause i dont have the reciept.
Also Dual Channel basically is pointless on Athlon XP's.
Try running them on the same channel.
==>Lazn
ooh
well im getting another bios chip... and im gonna try and use that modded bios
did it work for u 100 %?
and what do u folks mean dual channel is useless? is there an article i can read??
I'm also having similar problems.
I have an Epox 8KDA+ mother board (single channel), with an Athlon64 3400+.
I've got an older stick of 512MB pc3500 Kingston Hyper X RAM (I believe it's CL2)
I also ordered a 2x512MB pc3500Kingston Hyper X RAM CL2.5.
I've had all sorts of problems, BSOD's and reboots to name a couple, also the BIOS has been doing interesting things. Sometimes it boots fine, sometimes it gets stuck at post, sometimes it doesn't boot at all. You can usually fix this by powering off a few seconds.
I've tried pretty much everything, will be troubleshooting again soon, I lost my data on a 240GB RAID array (yeah, serves me right for not backing up, but all this BIOS being crappy is what triggered it)
I've run memtestx86, all seems well.
But it may be a while before I can try stuff out, and I need to get an idea of my options before the RMA period runs out.
1) Are there any issues with this motherboard ie, using a certain amount of sticks, low voltages or anything of that sort?
2) Although I can set the CL level and the other RAM timings to be the same as the slower dual channel sticks, could this be a cause?
3) What's so special about dual channel RAM? Is it physically different from buying them seperately, and could the dual channel RAM be conflicting with the exitisting sinlgle stick?
Also is there any reason that dual channel RAM wouldn't work in a normal single channel board, or would it work, just not in dual channel mode?
4) Any chance the CPU is dead, or would BIOS report something?
5) I've tried different arrangements of the RAM, some of the orders make it possible to boot, but the BIOS acts weird, sort of like when you overclock a bit too far/don't apply enough voltage.
Other arrangements gave me beep codes.
I really appreciate any help, I've got a music video convention coming up, it's looking increasingly impossible for me to participate. Thanks :)
Did u run memtest all the way? cause i thought all was fine until i finished the test. like 1000+ errors
I get all the same errors u do dood
Yeah thats what i get too btw.. bSOD's... before it crashes... windows event manager doesnt even record any errors ..so i wasnt able to deduce what was teh problem until memtest 86+
Luckily my dads workplace can flash my dead bios.. so im in luck
Inquisition said:
ooh
from: http://www.digit-life.com/articles2/nforce2-1vs2channels/
"First of all, the dual-channel mode of the nForce2 always makes a positive effect, and taking into account that this mode actually costs nothing (it needs two smaller memory modules instead of one big module), it's very possible to get the performance growth of 2-4%."
woo 2-4%
and here: http://www.amdmb.com/article-display.php?ArticleID=244
you see in the benchmarks, sometimes the single channel Nforce2 MB outperforms the dual channel one. - Though I think they messed up in their testing here...
edit: more here: http://www.lostcircuits.com/motherboard/asus_a7n8x-x/
"The differences are not huge but still in the order of about 3% in favor of the dual channel setup."
and
"Cachemem 2.65MMX, lower is better: Both systems show alost indistinguishable memory access latencies, however, the single channel board (solid columns) is on average about 2ns faster than the dual channel solution (transparent columns). "
==>Lazn
