Motherboard...or CPU?
Circuitbreaker8
Hey guys, for some reason, my CPU ( A64 3400 Claw CG ) doesn't wanna OC anymore! Its 100% prime stable for 9 hours @ stock settings, but once I try to hit the previously stable 2.4ghz, it crashes all the time!! Do you think its my motherboard or CPU? I ran memtest on my RAM and it tested fine for 8 hours....I need to have a fast CPU before BF2 comes out!! I'm using a Zalman 7000Cu with AS5 and the temps are around 35* idle/ 43* load
Have you done a BIOS flash or changed some settings since you had it overclocked? Or perhaps accidentally/on purpose reset the CMOS? Or did you just decide to one day take it back to stock for a reason of your own? Something must have changed, there is hardly a reason for it not to clock back up to what it was previously.
I cant really suggest anything apart from do a bios reset and try right from scratch. There should be no reason whatsoever for not being able to hit a speed that it was at up until recently, however, if the reason you took it back to stock was because it was crashing almost continually, you might just be seeing a heat problem. Take of your Zalman, clean the fins and the fan (compressed air), clean the CPU die and the heatsink base (polish it a bit too, oooohh......shiny.....) and put it back together with a fresh coat of the good stuff, namely Arctic Silver.
You really shouldnt have any problems, but I hope this helps.
Hm...I dont think its heat issues...my cpu heatsink isnt really dusty and its idling @ 34-36*....my freind said something could be wrong with the memory controller?
After you've already hit the speed you want in the past? It's unlikely. You burn a memory controller, you burn the chip. There's rarely a halfway point, and if there is, it would be next to impossible to run Prime95 stable for 8 hours or whatever and not have errors.
It _could_ be a problem with your motherboard? Maybe?
nF3 250 isnt exactly a cool chip, and the DFI probably runs hotter than most.
