Ok so I build a system every couple of years but I've never seen or heard of this. I bought an evga nforce 680i SLI and put a e6600 on it inside a gigabyte 3d aurora. I have two problems.
1) if I connect the power switch to the mobo, some strange things happen. I power on the system and it will run for a while then windows will go into hibernate and then a loud alarm type beep (steady tone) comes from the machine (still powered, fans still running etc). If I turn of the power off then wait a bit and turn it back on, the system tries to start up but like 3 seconds later it just powers off. The only thing I can do then is quickly pull the power switch plug and then the system boots and stays running normally.
2) I connected the hd auto front panel connector to the mobo and the system doesn't sense when I plug in a headset or mic into the front ports.
I appreciate any tips you guys may have.
