Motherboard opinion
netsider
For a really cheap experimental machine, would this be okay? Feature-wise, it has everything I need.. but just wanted everyones opinion anyway:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8209575&CatId=3779
I mainly just want it for linux, and maybe some Windows Server OS's. I already have a few fast machines, and mainly just want something I can leave running for doing networking or security stuff with... like light pentesting.
Just one of those cases where you need another machine, but don't really need it that bad either.
If there's anything else that may work, feel free to post that also. Thanks ;)
Edit: Also.. I looked that mobo up, and I'm pretty sure the CPU is some type of embedded pentium... I don't remember exactly. But, that's also another reason for me buying it.. so correct me if it doesn't come with the CPU. This was the other one I was looking at (because it's also ITX, and has an embedded CPU), but it looks kinda funky and uses SODIMM's instead of regular DDR3 DIMM's (and it's +$20, and there's other parts I'd need).
It is indeed an embedded pentium. Recently built a machine for my mom using a board similar to that one. No issues with it, however she doesn't do anything beyond facebook on her computer.
That thing is old and refurbished. you can get a much newer better embedded option for that price. The other one uses laptop dimms but the j1800 really isn't much different from the celeron 847 and 1037 while being quite a bit more expensive. It's based off of the atom architecture (so its cores are slower in gettting work done but clocked higher so they are roughly the same) while the celeron 847/1037 are based off of the core (sandy or ivy bridge) architecture (the cores are faster in ipc than the j1800's cores).
Here's an option
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138393&ignorebbr=1
and heres another
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138368&ignorebbr=1
65 for a refurb? Meh
But of course its tigerdirect....
Go to the egg and get the chepest ITX you can find Im sure it will be cheaper then 65
