Motherboard only boots first time
reflex33
OK... I'm trying to troubleshoot my brothers computer here. The motherboard is a EPOX EP-9NDA3J with an Athlon 64 3000+. On powering up the board with only bare components (CPU, memory, video card) the board posts fine. After shutting the power off and trying to power it up again, the board momentarily receives power (leds and fans start to spin) for about 1/3 of a second, then the board just shuts off and then refuses to even do that much on subsequent power cycles. If I let the motherboard sit without the power supply hooked up for about 10 mins. or so, I can repeat this whole process.
This is very confusing since the board powers up successfully the first time, and therefore should power up everytime, but it doesn't.
Just for reference, I have tried different video cards, I have tried powering up with and without memory, and have verifed that the power supply is 100% perfect and giving proper voltages.
Any help would be greatly appreciated.
well-- some of the DFI's has some similar problems
have you tried the one stick of ram trick --?? you just use one stick of ram--and switch it around from one slot to the next untill it either works right or you run out of slots .
another thing to try --on boot go into the bios and check where the ram is set -it might be auto setting to some specs the ram can't take.
and another bios trick --it may be undervolting the ram--in the bios set the v-dimm manually.
last trick -- it may be a bug in the bios--get the latest bios from epox and flash it to the new bios--clear the bios and start over.
my a8v-delux had a start up problem with the venice cpu--but a bios upgrade fixxed the problem. my asus a8n-sli has the cold boot problem--a bios upgrade fixxed that--and my dfi-lanparty ultra d had a cold-boot clear cmos issue--a new bios fixxed that--
so maybe a bios update will have a cure for this issue as well. :cool:
I assume you've reset the CMOS already?
Try another PSU regardless of whether the current one appears to be working fine. Some Abit boards, for example, wouldn't even boot with certain supplies due to some timing issues.
nf4 are very pickey about psu's and it is the quality of the power that is the issue.
a psu can test good and still have issues because nf4s hate any kind of power flux or voltage hopp--
ive had good luck with antec's --but if you got a generic or "repackaged/re-braneded psu--even if it tests good--it could still be a problem--if you have a good antec or other quality psu test it with it . might be the problem all along :cool:
Aaron_ATX said:
Had some strange issues like that with my EPOX as well
http://www.aoaforums.com/forum/showthread.php?t=31119
turned out to be the powersupply (which still works fine on my older XP system)
Yea, but the PS that worked great with my Pentium II doesn't work either :p
Seriously though, nForce4 939 boards are much more power demanding than the older XP setups were. These newer setups are really showing the variance in PSU quality that wasn't so apparent with older setups.
Go ahead and use the search function for peoples recommendations with the nForce4. I'm currently using an Enermax EG465P-VE that works very well with my newer 939 nForce4 setup.
Good luck and let us know how it goes.
Ok, I got it to boot consistantly by using the "hold the power switch while you power up the power supply" trick. This makes me think that these motherboards have a serious power regulation problem. If a quality 480 power supply has problems booting this board up now and then without "shocking" the system into booting... then something is wrong.
Good news is though that at least my bro has a usable way to power up his system until we find a better solution.
