Motherboard Not Posting!!
gist901
Hey, i recently bought a new computer case, and transfered my computer into the new case. When I powered on later, I as not getting a video signal. So I slowly started disconnecting everything, until the only thing left connected to my MB was the VD, and the mem. Nothing changed throughout this whole process, no vd signal, and no beep from my MB. I have also removed th MB and still got no results. I believe it is my MB, but any thoughts or considerations would be useful.
Thanx
Were you having any problems with the computer before you moved it to new case?
What brand and model is your motherboard?
No I was not having any issues w/ my computer before moving it.
My MB is an Asus p5n32-e sli. I have already RMA'd it, but I just want to make sure there is nothing that I can't try before sending it out for a week or 2.
Was it a brand new case? I moved a motherboard to a used case once and the power switch was bad.
Is there a power led on the motherboard?
Yes it was a brand new case, it was a CM-690 case. The power button is working properly, as well of the LED on the MB shows green.
I would try the usuall tests.
1. Remove power. Reset cmos by moving the cmos pin to the "shorted" postion. Remove
the cmos battery. Then replace the cmos pin back and reseat the cmos battery.
2. If you do not post, then turn off power(take out plug from back off power supply) and
remove the ram. reconnect power. You should have warning memory tones.
3. If you do not have tone, more than likely you have a bad bios chip.
Have a nice day.
