motherboard, northbridge temps, concern?
wadec22
Hey guys,
Got my system running a pretty solid, perfectly stable overclock. My motherboard reads really high temps though, 47c IDLE, 55 up to 60c full load! The northbridge is around 42 idle and up to 50 full load. Should these mobo temps be a concern? I think the 55 to 60 is around the power management area. Everything seems totally stable for over a week now. If it is a concern... any cooling recommendations? I have two 80mm case fans blowing in, a hyper 6+ with a 100mm fan (cpu is 44 full load), a 60mm in the mid back of the case blowing out, a cool drive 4 hd cooler, and a bay drive cooler in the top 5.25" bay that has two 80mm fans sucking air from the top and blowing it out. Things don't really heat up in my case until my 7800gt(460/1.2) kicks into high gear. That puppy hits 62c easy! I have coolbits running the gpu fan full time. Idle case temp hangs around 32-33. Thanks for any info guys.
My system:
DFI N4 Ultra-D HTT 260
3200 Winchester (2.6, 10x260)
OCZ Plat Rev 2 (actually running just below stock w/mem divider)
while a given case, and a specific list of components and fan locations isnt necessarilly unique, it might as well be, as its not a fully modeled thermal solution (unlike an OEM machine), thus its trial and error on your part, there are substantial benefits to running cooler, if you want the components to last their full lifespan (most will likely upgrade before that however)
to answer the question, you could simply have a hot spot in the airflow pattern being picked up by the sensors in question, you could have a high ambient room temperature and poor airflow into and out of the case (you often see obstructions to airflow with cases in little desk hutches), a misbalance in airflow (over or under pressurized) or just a poor airflow pattern.
One of the advantages of a movable sensor (like in a DigiDoc) is tha ability to map your case's temperature gradients and finetune your airflow.
Based on your description Id guess youve overpressurized the case with far more fans blowing in and restricted its exit, thus the interior ambient is artificially high, which decreases the ability of all your heatsinks to transfer heat. Heat transfer is all about differential temperatures
http://www.pcper.com/article.php?aid=-105
what happens when you take the side panel off?
youd be suprised what kind of effect a simple paper duct or divider can sometimes have, or simply a small fan in the right spot, but its tough to recommend that without a personal experience of your specific config. Barring someone showing up that has a similar layout of heatsources, you need to experiment.
thanks. I swithced the drive bay cooler to the bottom 5.25 bay, seems to have helped. Idling at 44c on mobo now. Gonna try gaming for awhile and see where it goes. If this doesn't fix it, I think I'm gonna get a slot cooler to stick right above that 7800gt to blow hot air out.
sounds like a plan
a little trial and error can go a long way ;)
when doing that the really important part is to observe the room ambient
try to do your experimenting when its close to the last time you where experimenting
Good Luck
