So I finally got my ASUS Z87-PRO yesterday and started to build my new Haswell PC. A friend of mine with a good deal of experience came to help out, and we tried an external build and kept receiving memory errors. After swapping RAM out we found out that my second memory slot was the problem, and decided I had to return the board.
And now for the nightmare...
After removing the CPU and memory I started to put away components, and my friend takes the plastic CPU socket cover, places it underneath the bracket for the CPU, and lowers the tensioner, bending and wrecking a number of pins in the CPU socket. I have no idea what to do at this point; I can try to send the board back to ASUS for the memory slot, but I have a feeling they're going to notice the CPU socket is damaged. Will I be charged something for a repair of the socket if I return it complaining about the memory slot, or will they not even replace the board at all with the physical damage and I'm out $200? We tried to bend the pins back into place but it still isn't pretty. Do I even want the board if they're going to perform surgery and replace the socket on an already defective product?
Advice would be greatly appreciated.
