Motherboard mounting spacers
Tokken18
Last night i was puting together my computer when i went to mount the motherboard i noticed that there were no rubber or plastic or any kind of a spacer for the motherboard, it would be sitting right on the metal screwstand attachment things. The case nor the motherboard came with anything and although this is my first build, i read somwhere that the mounting stuff is usually rubber or something. So, my question is, do you think this will be a problem? It's an ASUS A8N-SLI Deluxe and the case is a COOLERMASTER Wave Master. Any thoughts would be greatly appreciated.
I never use them anyhow... I was actually told NOT to use spacers, and just have the mobo bolted directly onto the studs. I have built roughly 100 machines in the last 4 years, and not one has used rubber/plastic/etc... spacers.
QJ
ahh, thanks. Seeing as this is my first build and actually a rather large investment i am quite worried about my ability to construct a pc. All these random little things seem to add up. Thank you for easing my mind.
