Motherboard LED light
ninty
Well, here's a bit of an odd question but here goes.
Finished building my system yesterday and it looks and works great. I decided that I want to put it on top pf my desk instead of underneath so I can show off my work and so I can admire the beautiful rig myself.
Only problem is that the green motherboard LED is bloody bright and shines directly in my face when I go to sleep. it lights up the whole room when dark.
I don't really want to disable it, but does any one have any suggestions to get around this?
What I did last night was put a cardboard box from my router against the window which contained the light inside the case, but I don't really want to have to have a box lying around every night to lean up against it.
Thanks.
You can mute out the intensity with some thin white paint or a suitable substitute. I don't think motherboard LED's get so hot as to have a negative effect on paint or a sharpie.
Simple, take a pair of needle nose pliers... squeeze until you hear a "crunch". Blow off the debris and you're good to go.
:D
The board is an ASUS P5K Premium, and the light isn't brighter than any other mobo light, I think it's just the position of the computer since the light shines directly in my face.
Anyway, the paint or tape should work well. Thanks for the suggestions guys!
I'd use tape, unlike paint, it doen't VOID the warrenty ;)
I had the same problem with my uber bright case LED. I just covered it with some black permanent marker. It'll look like a black bulb when off, and you can still see the light when it's on, just a lot dimmer.
Also, if you're worried about putting "permanent" marker on it, it comes off very easily with a paper towel and some alcohol.
