Was changing out my hard drive and went through everything, proceeded to power up with the onboard mobo led coming on along with usb hard drive spinning up. Both those things were able to power up, but my cpu fan, internal hd's, and vide card fan did not power up. Searched around found a screw had dropped down onto the mobo next to a pci slot, and appeared to be creating a short between two points. Tested with a seperate power supply which didn't change anything. Is it possible for a screw to short a board, and if so should I be concerned about my cpu, ram, and video card.
