-Motherboard Issue Please Read -
theDon
I have an Asus A8N-SLI Deluxe board. Was running like a champ with a 4600 X2 installed. I traded for the board on this forum, but it came with a 3700+ 64 which ran great in it till I upgraded. I bought a laptop and reshuffled some hardware around I gave my kids the 4600 X2 machine with a reinstalled Vista. All ran well, but I shuffled more stuff and sold the 4600 X2 and reinstalled the 3700+. I checked the pins and the socket multiple times but when I power on the the 3700+ fans/drives/lights start, but no post of video signal. I had already sold the 4600 so I could not keep it but to test I put it back, and it all worked fine. I already accepted the paypal so I shipped the 4600 on which worked great for the buyer. knowing the board worked with one chip but not the other I figured in the interrum something must have went nutty with the old 3700+. So I bought a new 4000+ 64 from Newegg got it in and it does the same as the 3700. Has anyone had this happen before? I cleared the CMOS several times with no success. Any advice would be appreciated, and if it's dead a good price on a 939 mobo even more so.
Thanks
TD
So just to clear up the problems it is causing is, the board is getting power but their is no post.
Are you using on board video or a PCI, AGP, PCI-E card? If on board I would try using video card to make sure the onboard did not go bad if you already have not done that.
Besides that its a pretty weird issue? Have you done a BIOS reset, removing the CMOS battery?
Thanks for the reply.
It is using PCI-E video. The card worked with the 4600 X2 and previous to that it worked with the 3700. There is no onboard video or AGP. I tried reseatting that card to be safe. I removed the battery and cleared the CMOS, and then broke out the manual for the ASUS way to clear CMOs both of which makes no difference. All of it appears to power up. My ram has indicators of activity which seem to come as normaly but after 10 - 12 seconds the light goes off of there.
Ugh..
TD
check the pins? any bent or flat? check the socket as well, make sure no debri is in there that may cause it.
certainly a very odd problem indeed...I've never seen something like that.
Obviously your board felt the "powa" of the 4600+ compare to the 3700+ and wants nothing but that. :p
Debris.. I had not thought of that.. I will blow/vacuum the socket.
Thanks
