Motherboard issue or something else?
Cook_1
This happened last Sunday night, between school and my multi jobs haven't had a lot of time to put much thought into it.
Let me know what you all think.
I have an Asus A8N-SLI Deluxe w/SB Audigy Platinum running on Win XP Pro.
I was playing EQ2 and listening MP3s at the time. All of a sudden I get a blue screen of death, I read something about device drivers before it rebooted. Was confused because I've been running this same system for about a month now, and haven't put anything new into it.
So I think that I OC'd it too far for EQ2 (even thought like I said had been running fine and stable for about a month). So I went into my BIOS and went down on my OC. When I booted back up into Windows my sound was gone...nothing, nada. I open up Musicmatch and start to play an MP3 and I got this constant high pitched beep noise that stopped only when I clicked stop on the player.
Thought I blew my speakers, tried two pair of headphones that I know work, even tested them with my MP3 player and it worked. So then I thought I blew my sound card somehow, so I disable it, take it out and uninstall the drivers. Then install the drivers for my onboard sound. Reboot, open up Musicmatch, start to play a song, everything is going well then about 40 seconds into the song I get that same high pitched constant beep that stops when I click on stop on the player.
Ok, so then I throw another sound card in there, do the same steps as before, and I get the same problem.
So then thinking it might be a software issue, I took out my XP Pro disc, rebooted, deleted the partition, recreated the partition, formatted the long way (thinking this might help, I dunno, I was desperate) and did a fresh install of Windows. No go...
Now I'm soundless and it's driving me crazy. I have about 500 MP3 and I have to listen to music when I'm on my PC.
I contacted Asus tech support and they were very much so not helpful. They told me to do a fresh install of Windows (which I already did and told them I did), then they said that my PSU wasn't good enough. I have a brand new Forton Blue Storm 500W PSU, has duel 12V rails at 15A each...not the issue.
So, what do you all think?
