I am working on a friends system it is a HP (problem right there) a1230n. The system specs are A64 3700+ sandy, 1gb PC3200 memory, 200Gb Maxtor diamondMax 10 on a ATI 200 express board. The issue is they were receiving the error" Disk Boot Failure, Insert system disk and press enter" So my first thought was that a disk was in the floppy or cd-rom and it was set to boot to either. It was not the case. So I ran seagate's diagnostics (on the original drive) the drive was bad and was not under warranty. I replaced it, started loading Windows and got BSOD during the installation found out the memory was bad. This computer was placed inside a small area I imagine it overheated or got hot enough to shorten the life of the components. Anyway with memory and hard drive replaced. I loaded XP ran all the updates and loaded all there software. Shut the system down and came in the next morning to finish it up. Guess what I got the same error Disk Boot Failure, I manually powered it off and back on booted into Windows. Bad cable mabey replaced it. Shut it down again and viola` same error. Shut down again and re-booted went into Windows Updated the bios it was way out of date. Shut down and restart same error this time it will not boot into Windows. I unplugged everything from the board except the HD and still the same error. Could it be a mainboard issue or PSU? Bye the way I get this error with PATA or SATA. Thanks.
