Motherboard id (PCCHIPS)
Gk22CoE
I can't get this motherboard to locate harddrives... I've had this problem before and a bios update fixed it. Only problem is the only thing i know about the board is it's made by PCCHIPS because i found this computer at a recycling center. I need to know the model number to figure out what bios i need.... heres the pic
http://home.comcast.net/~gk22coe/IMG_0745.JPG
thankx
Usually there is a model & version number on the mobo itself, if not a sticker. I'd look it over closely and google any numbers I found.
It used to be PCChips would put stickers with their model numbers on the bottom edge of the last ISA sot. This is obviously a much newer board then, so things may have changed....
In cases like these I usually just fire up cpuz.
http://www.cpuid.com/cpuz.php
Usualy pretty good about getting a model number.
Perhaps this has changed since the last time I worked on a PCChips motherboard (M920L, IIRC), but doesn't it tell you the model of the board at POST?
Yes, it does, and this is very liekly where CPUZ gets it's info from.
ok found out is has SiS 900 chipset through bios.. now i just need the board revision number
