Motherboard hotter than CPU?
Davermonk
I just put my system together. AN85X board, 3800 X2 CPU, WD Cav SATA drive, Sapphire X1900XT GPU, Antec TP 2.0 PSU. Stock hs/fan with the cpu and no o/c (at this time). This is all in an Antec TX 1050B server case with 2 fans in & 2 fans out (not counting the PSU fans).
The Asus software is telling me that my MB runs 38-44C while my CPU stays at 28-32C (at "idle").
I e-mailed Asus tech support about the mobo temps and they replied that 50C was in the "safe range" and "up to 70C" was nearing the shutdown temp.
Could my mobo temp be reading higher because something else is generating heat near the MB temp sensor? I have no idea where the temp sensor is on this board.
Any thoughts would be appreciated.
Edit: I just ran 3DMark 05 to see what it would do to my temps. Immediately following the test, the motherboard temp was 43C and the CPU temp was 41C. Two minutes later, the MB was 41C and the CPU was 38C. Ten minutes later, the MB temp is still 41C and the CPU is down to 30C.
Asus probe is reading sensors incorrectly, how about the readings in Bios, are they messed too?
Try looking for an upgrade for asus probe and see if that helps
oldmx
Actually, AsusProbe seems to be pretty close to the bios readings.
I just checked bios (after playing a game for an hour): cpu temp was 40C, MB temp 44C
(that's within 1 degree of what Asus Probe said just before I checked bios)
If the MB temp never goes above 45(ish), do you think I'm ok? Or should I look into getting some bigger case fans? Noise isn't really an issue (within reason).
