Motherboard Help
Ok so I recently got a new case (Antec Twelve Hundred Full Tower) and I transfered all the parts from my HP Pavilion Media Center m8120n connected everything and hit the power button. Nothing happened. To give you guys some specs...
HP Pavilion Media Center m8120n PC
Core 2 Quad Q6600 (K) 2.4 GHz
1066 MHz front side bus
Socket 775
Intel P965 Chipset
Asus P5BW-LA Motherboard (HP/Compaq name: Basswood3G-UL8E)
640 GB (2 x 320) SATA 3G (3.0 Gb/sec) 7200 RPM
I'm running a ZEROtherm Nirvana NV120 120mm 2-ball UFO Bearing Fan on the motherboard rather than the stock CoolerMaster. And I had upgraded the video card to a Nvidia Geforce 7950 GT when I bought it along with a 700 W power source.
Now my concern is that I probably hooked up the motherboard incorrectly and so I am wondering if anyone can give me direction on it and possibly a diagram. The diagram of the mobo on HPs website sucks and I can't read it. And before anyone suggests... yes I "plugged it in" lol.
I plan on upgrading my graphics card to the Geforce 9800 GX2 once I get this running again so anyone have an idea on if and how much I should upgrade my power source?
Please, I really need help on these two things. If you need more info just ask. :)
Well this may be unhelpful, but it's happened to me where either at the front or on the motherboard the power button is not connected. Other than that, I had an old mdg computer that wouldn't start, so I sat it on its side and it worked. Not saying that that will neccessarily fix it, but saying that you could have done everything right and it's there's just a weird solution. Can't help with the psu specifically, because idk what it is, but this may help http://www.anandtech.com/casecoolingpsus/showdoc.aspx?i=3413. Good luck :)
Well, since you mention it, I did take another look and I had forgotten to connect the power button to the motherboard in all the tangled mess of wires. But I have it up and running now thanks for the input though. Now I just gotta get rid of my old drivers and install my new graphics card.
