Abula
- Oct 29, 2004
Hi,
I'm doing a PC that will be multipurpose, not 100% server, but a combination of a lot of things, i was going to post on the motherboard section, but upon checking with LSI about thei raid controller, they said some consumer grade mobos might have issues with LSI raid cards, so i decided to build around a server board or a workstation.
I want to find a motherboard that can run the following
1) GTX1080ti (dual slot minimum or 2.5 slot more likely). ----> 16x PCIe
2) LSI 9271-8i (for building a raid 6 with 8x 4TB Seagate drives) -----> 8x PCIe
3) Datapath HDMI Capture card (for recording two HDMI cameras) -----> 4x PCIe
4) Intel 900p 480 PCIe SSD (for compiling and editing) ---> 4x PCIe
Most of the consumer grade mobos, are 8x8x4. Threadripper has a ton of PCIe lanes, so i was ser on building aorund a 1950x, specially with the $799 pricing some days ago, until LSI said the card might or not work. Also i discarded Threadripper for some issues that i seen on their forums about not using fully all cores and that it loses to lower corecount cpus as adobe is not design or optimized for it.
So help me find a server or workstation/server motherboard that can hose that hardware. Its mainly going to be a headless PC that will be capturing video from different sources, at some point it might stream as secondary pc, and will be the rendering workstation for adobe premiere, afterefects, davinci, etc.
There is no set budget for it, just looking for something that will work, else i might just give up on LSI raid card and go back into a consumer grade mobos.
